RedBullet's avatar
Oct 03, 2018
Model Identification of JGS524 Series Switch
I haave a JGS524 unmanaged switch. I'm trying to find some technical specs on it, but I see two over versions of this, v1 & v2.   I assume mine is NOT the v2, but is it the v1? or something else?...
  • DaneA's avatar
    Oct 04, 2018
    Hi RedBullet,
    If you have the JGS524 switch model, it means that you have the JGS524v1 (v = version).
    Here below are the differences between JGS524v1 and JGS524v2 switches:
    To know more about the JGS524v1 switch, check its datasheet here.
    For more information about the JGS524v2 switch, check its datasheet here.
    DaneA
    NETGEAR Community Team
