RedBullet
Oct 03, 2018Tutor
Model Identification of JGS524 Series Switch
I haave a JGS524 unmanaged switch. I'm trying to find some technical specs on it, but I see two over versions of this, v1 & v2.
I assume mine is NOT the v2, but is it the v1? or something else?...
- Oct 04, 2018
Hi RedBullet,
If you have the JGS524 switch model, it means that you have the JGS524v1 (v = version).
Here below are the differences between JGS524v1 and JGS524v2 switches:
To know more about the JGS524v1 switch, check its datasheet here.
For more information about the JGS524v2 switch, check its datasheet here.
DaneANETGEAR Community Team
schumaku
Oct 04, 2018Guru - Experienced User
Checkt the product label model information:
JGS524-100xxx (like JGS524-100EUS) == v1.
JGS524-200xxx (like JGS524-200EUS) == v2.
RedBullet
Oct 04, 2018Tutor
Thanks for the replies. I probably can't take advantage of jumbo frames. So, aside from that anyone think it would be worth upgrading to v2?
Or perhaps a different unmanaged switch?
Thanks, appreciate the feedback and opinions.
- DaneAOct 04, 2018NETGEAR Employee Retired
For me, if ever your current JGS524 switch is not giving you any problems which means its still working fine, I suggest you to stick with it in order to avoid unnecessary cost.
Let me share the link below where you can select the switch that matches your network requirements:
