RedBullet
Oct 03, 2018Tutor
Model Identification of JGS524 Series Switch
I haave a JGS524 unmanaged switch. I'm trying to find some technical specs on it, but I see two over versions of this, v1 & v2.
I assume mine is NOT the v2, but is it the v1? or something else?...
- Oct 04, 2018
Hi RedBullet,
If you have the JGS524 switch model, it means that you have the JGS524v1 (v = version).
Here below are the differences between JGS524v1 and JGS524v2 switches:
To know more about the JGS524v1 switch, check its datasheet here.
For more information about the JGS524v2 switch, check its datasheet here.
DaneANETGEAR Community Team
RedBullet
Oct 04, 2018Tutor
Thanks for the replies. I probably can't take advantage of jumbo frames. So, aside from that anyone think it would be worth upgrading to v2?
Or perhaps a different unmanaged switch?
Thanks, appreciate the feedback and opinions.
DaneA
Oct 04, 2018NETGEAR Employee Retired
For me, if ever your current JGS524 switch is not giving you any problems which means its still working fine, I suggest you to stick with it in order to avoid unnecessary cost.
Let me share the link below where you can select the switch that matches your network requirements:
DaneA
- RedBulletOct 04, 2018Tutor
There is also a JGS524NA? What's the one exactly?
- schumakuOct 04, 2018Guru - Experienced User
That's a different thing, it's the SKU for a JGS524 switch for the market with US 110V power supply and the do-not-put-it-into-the-microwave-oven-label.
So that's basically the v1 of the switch?
(removing my network gear from my microwave oven)
