Sbinoc
Mar 07, 2025Tutor
Modem ethernet to switch not working
My office has a hardwired ethernet outlet. I get connectivity if I plug a device (computer, Xbox and tv) directly in the outlet. My issue is if I connect my GS108 switch to the outlet I have no intern...
Kitsap
Mar 07, 2025Master
Sbinoc wrote:
My office has a hardwired ethernet outlet. I get connectivity if I plug a device (computer, Xbox and tv) directly in the outlet. My issue is if I connect my GS108 switch to the outlet I have no internet and the switch lights are not on.
Someone is in control of the hardware and it's configuration that feeds the Ethernet outlet in your office. You need to address this question to that someone.
- SbinocMar 08, 2025TutorSorry, it is my home office.
- KitsapMar 08, 2025Master
Sbinoc wrote:
Sorry, it is my home office.Where does the feed to the hardwired Ethernet outlet box connect to your local network?
You are going to have to describe/communicate all of the pieces to your local network. Start with the modem/ONT that is your connection to the internet and work towards the router, switches, computers, and other connected devices. It really helps for you to use brand names and model numbers for each piece.
- SbinocMar 16, 2025TutorCalix Gigaspire Modem/Router to
Netgear GS108 unmanaged Switch.
Devices connected directly to RJ45 Jack in home office works great but if connected jack to switch there is no connection.
