Sbinoc
Mar 07, 2025Tutor
Modem ethernet to switch not working
My office has a hardwired ethernet outlet. I get connectivity if I plug a device (computer, Xbox and tv) directly in the outlet. My issue is if I connect my GS108 switch to the outlet I have no intern...
Sbinoc
Mar 08, 2025Tutor
Sorry, it is my home office.
Kitsap
Mar 08, 2025Master
Where does the feed to the hardwired Ethernet outlet box connect to your local network?
You are going to have to describe/communicate all of the pieces to your local network. Start with the modem/ONT that is your connection to the internet and work towards the router, switches, computers, and other connected devices. It really helps for you to use brand names and model numbers for each piece.
- SbinocMar 16, 2025TutorCalix Gigaspire Modem/Router to
Netgear GS108 unmanaged Switch.
Devices connected directly to RJ45 Jack in home office works great but if connected jack to switch there is no connection.- KitsapMar 16, 2025Master
Devices connected directly to RJ45 Jack in home office works great but if connected jack to switch there is no connection.I am sure that Calix Gigaspire Modem/Router has a model number on it somewhere. Most likely on the nameplate.
I am not at all familiar with the Calix series of devices. Recommend you look into the user configuration to see if a setting is preventing assignment of IP addresses through your switch.
Do you know who initially setup the Calix modem/router?
Is your internet service delivered over coax, fiber, something else?
- SbinocMar 16, 2025TutorMy ISP setup the modem/router and it is fiber.
GigaSpire Blast
Model: u6.1 GS4220E
Kitsap County?
