Sbinoc
Mar 07, 2025Tutor
Modem ethernet to switch not working
My office has a hardwired ethernet outlet. I get connectivity if I plug a device (computer, Xbox and tv) directly in the outlet. My issue is if I connect my GS108 switch to the outlet I have no intern...
Kitsap
Mar 16, 2025Master
Sbinoc wrote:
Calix Gigaspire Modem/Router to
Netgear GS108 unmanaged Switch.
Devices connected directly to RJ45 Jack in home office works great but if connected jack to switch there is no connection.
I am sure that Calix Gigaspire Modem/Router has a model number on it somewhere. Most likely on the nameplate.
I am not at all familiar with the Calix series of devices. Recommend you look into the user configuration to see if a setting is preventing assignment of IP addresses through your switch.
Do you know who initially setup the Calix modem/router?
Is your internet service delivered over coax, fiber, something else?
Sbinoc
Mar 16, 2025Tutor
My ISP setup the modem/router and it is fiber.
GigaSpire Blast
Model: u6.1 GS4220E
Kitsap County?
GigaSpire Blast
Model: u6.1 GS4220E
Kitsap County?
- KitsapMar 17, 2025Master
GigaSpire Blast
Model: u6.1 GS4220E
Kitsap County?Since your ISP set up your modem/router, they would be the first point of contact to ask about connecting a switch downstream of one of your Ethernet outlets.
Yes, Kitsap County.
What area are you located?
- SbinocMar 17, 2025TutorGrew up in Bremerton
