Elsydeon's avatar
Elsydeon
MS108UP and 802.1Q tags
I will be setting up a network for a friend who wants an isolated guest Wi-Fi network using 4 WAPs since his apartment has a big steel column in the middle of it.
Since we want to isolate it, we want to create a dedicated VLAN and SSID for this network, which the WAPs (Netgear WAX630e) support.
To power his WAPs (and make cable management a little easier) I am using a POE++ switch (Netgear MS108UP or MS108EUP) to inject power and provide.
The question I have is if the WAPs send frames with 802.1q tags and I use the MS108UP (the unmanaged switch), what will happen?
1 Reply
  • schumaku's avatar
    schumaku
    These are not unmanaged switched in this aspect. The VLAN(s) must be defined before, the port must be defined to carry [T]agged frames for specific VLANid(s), and defined for the VLAN where untagged will be associated to [U]ntagged and PVID.
    Said that, there must be a router able to deal with the additional VLANs and the additional IP subnets and to provide DHCP services.
    Welcome to the wonderful world of 802.1q VLAN aware networks.
ProSupport for Business
