PaladinKC's avatar
PaladinKC
Multi-Gig Switches and Google 2 gig fiber
This one has me at my wits end!  I recently purchased a Netgear Multi-GIG XS505M to take advantage of my new 2 GIG Fiber connection.  In addition, I added a 10 gig ASUS XG-C100-C card to my PC.  Connections as follows:  10 GIG line out of Google router into switch port and 10 gig out of PC into switch.  All link lights show 10 gig connection.  However, when I run Google speed test, it only shows 576 MB down.  To trouble shoot I tried all 4 ports ...no difference.  I connected PC directly to Google router ... 2,036 down.
Called Netgear support .. they determined switch was apparently bad.  I replaced today with new switch and EXACTLY the same happened!  The switch is knocking 75% off the speed.  Any ideas?
Thanks....
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    PaladinKC,
    Welcome to the community! :)
    Found out from the NETGEAR Support Team that you already have opened a support ticket about your concern.  You may want to share the progress of your support ticket here.
    DaneA
    NETGEAR Community Team
    • PaladinKC's avatar
      PaladinKC
      Thank you for the note.  I downloaded the most recent drivers when I installed the card.  I'm a little skeptic if the drivers linked ... there are no Windows 10 drivers listed ... If they haven't updated drivers since WIndows 7 and 8 ... I'm concerned!  :-)
ProSupport for Business
