grups's avatar
grups
Follower
May 29, 2018
Need Letters or Volatility for several products
Hi,   I'm looking for LOVs for the following items: DS104 JFS516 JGS516   Thanks in advance for your help. Regards, Grups
  • DaneA's avatar
    Jun 03, 2018
    grups,
    Just a follow-up on this.  Were you able to download the Letter of Volatility of the JFS516 & JGS516 switches?
    If ever you were able to download it and you have no further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
