FEN436
Jun 10, 2024Follower
Netgear GS116LP
I'm not sure if anyone here can help?
I had the above model and it failed during the warranty period.
Netgear recently supplied a replacement unit (different serial number)
It failed after three weeks.
I have a switch working, I use as a backup. (Not a Netgear Unit)
I used it during the Netgear failures.
Here is the question. Is the failed replacement unit covered under the Normal Netgear Warranty.
The reason I ask is because Netgear changed the purchase date of the replacement unit. To the purchase date of the first unit. This is in fact false and not the purchase date as it was a replacement unit provided 3/4 weeks ago.
I found this information on the changed date under Mynetgear.
Thanks, any advice would be appreciated.
If Netgear is providing a warranty exchange replacement unit, the original date is retained, no matter how many times and when the units was replaced, the total warranty period is not extended. The warranty time starts with the date of sales.
FMI: LIMITED HARDWARE WARRANTY
Some of the essential warranty details are on the 8-port and 16-port Gigabit Ethernet Unmanaged PoE/PoE+ Switches GS108LP, GS108PP, GS116LP, GS116PP Data Sheet • Lifetime Warranty* plus lifetime online support and lifetime Next Business Day (NBD) replacement - for most markets
Power Adapter Warranty 2-years
Technical Support 90 days of free technical support
1 Reply
