albi_00
Oct 09, 2019Follower
Switch GS116LP disable Poe single port
Hallo,
Is it possible to disable poe at one port with the switch GS116LP? Reason, I have a door bell that runs with separate power supply and it is not allowed to have poe and power supply simultaneously.
Br
Albert
Br
Albert
Can't get rid of the impression having answered this or a very similar question some hours ago already.
The GS116LP is a completely non-managed switch - zero config options.
However, I'm not aware the very simple Smart Managed Plus PoE switches or the Smart Managed Pro PoE switches allow disabling PoE on a per-port base, too.
In any case, the PoE negotiation happen automatically on the link level.
1 Reply
