albi_00's avatar
albi_00
Follower
Oct 09, 2019
Switch GS116LP disable Poe single port
Hallo, Is it possible to disable poe at one port with the switch GS116LP? Reason, I have a door bell that runs with separate power supply and it is not allowed to have poe and power supply simultan...
  • schumaku's avatar
    Oct 10, 2019
    Can't get rid of the impression having answered this or a very similar question some hours ago already.
    The GS116LP is a completely non-managed switch - zero config options.
    However, I'm not aware the very simple Smart Managed Plus PoE switches or the Smart Managed Pro PoE switches allow disabling PoE on a per-port base, too.
    In any case, the PoE negotiation happen automatically on the link level.
ProSupport for Business
