GeorgiV
Jul 29, 2022Tutor
Netgear XS508M 10G Constantly Freezing Crashing Network Link to NAS
Hi all, We are a video production company and have built a 10Gb network for our 5 PCs and Synology DS 1821+ NAS with 10Gb NIC in our office. We are using Netgear XS508M 10G as a switch for it al...
- Jul 30, 2022
Probably a hardware issue. Head to https://my.netgear.com/ select the switch affected and follow the [Request Hardware Support]-
The XS505M operating here at home behaves rock solid.
GeorgiV
Jul 30, 2022Tutor
Hi schumako,
thank you for your reply!
Yes loosing network to all orher pcs, Syno and the internet at the same time. Same for all other pcs. Once we take the power cord out and in again it all comes back until 2-3 pcs start working together from the NAS at the same time again. It can happen few minutes after we just restarted the switch.
schumaku
Jul 30, 2022Guru - Experienced User
- GeorgiVAug 01, 2022Tutor
As suggested I wrote support and they even replied on a Sunday handling the situation like true professionals. They will be replacing our unit.
Very satisfied with the response both in here and with support.
Thank you all!
- Jan 17, 2024Retired_Member
