JohnJohnsonn
Dec 20, 2020Aspirant
No network access through switch
I have two PCs connected to a switch. One PC has no netowrk access. But when I connect it to a wifi router, it has access and everything works fine. Only when it is connected to the internet thoug...
No1Mportnt
Dec 20, 2020Luminary
Have you tried a different port on the switch for that PC?
JohnJohnsonn
Yes.
It also doens't have connection if I connect it directly to the cable modem.
Only has connection if connected to the wifi router.
- No1MportntDec 20, 2020Luminary
Does the router have a built in switch? If so connect your modem to the internet port on the router then connect your switch to the #1port on the router switch.
- JohnJohnsonnDec 20, 2020Aspirant
I don't want to do that because of two reasons:
1. The internet speed through the wifi router is half of the actual speed.
2. The router for some reason set my IP location 200 miles away from where I am and that cause security issues with some applications.
- schumakuDec 20, 2020Guru - Experienced UserOlder routers (make and model undefined) can have limitations which limit the throughout of your Internet connection (also unspecified).
Depending on the ISP there is only one device getting a full speed access, sometimes two. What you want or not isn't really relevant if you want a working network.
The router has zero impact on eg. the Apple or Google location services - all based in a database in fact. This database is feed from devices with exact location data provided by mobiles or tablets with GPS services.
- schumakuDec 20, 2020Guru - Experienced UserJust to confirm: It has access to the Internet if connected to the WiFi router LAB port?
Either way, the cable modem (one port only - correct?) must have one one connection direct to the WiFi router WAN/Internet port.
The switch and all other computers mit be connected to the WiFi router LAN ports only.
