airj1012
Jan 23, 2022Tutor
PoE Network Switch?
I have a panel containing all my ethernet runs to my entire house. I'm going to add a network switch to this panel to facilitate the internet getting to all the rooms. There is not a plug within the ...
schumaku
Jan 23, 2022Guru - Experienced User
No such small PoE switches - look for a GS110TPv3 (8x 802.11af plus two SFP uplink interfaces for fiber) or GS110TPP (8x 802.11af/at plus two Gb copper uplink interfaces). Same firmware, same UI, like the suggested GS108Tv3.
https://www.downloads.netgear.com/files/GDC/GS108Tv3/GS108Tv3_GS110TPv3_GS110TPP_HIG_EN.pdf
Sure, PD is mentioned in the title, in the comparison, visible on the pics for port #1
"NETGEAR 8-Port Gigabit Ethernet Smart Switch (GS108T) - Managed, with 1 x PD Port, Optional Insight Cloud Management, Desktop or Wall Mount, Silent Operation, and Limited Lifetime Protection"
Here again, watch your step, overly smart sellers might indeed offer similar designated products without PD. Everything oming from the official Netgear Store on Amazon should be fine.
airj1012
Jan 23, 2022Tutor
The GS110TPv3 and GS110TPP seem rather expensive when I'm just looking for PoE to power GS108Tv3 downstream. Can you use something like the GS305PP to power the GS108Tv3.
https://www.amazon.com/NETGEAR-Gigabit-Ethernet-Unmanaged-GS305PP/dp/B07WTXHSXC
I think the only "bell and whistle" I need is to power the middle switch. Thanks.
