Victorgo
May 02, 2016Aspirant
Product registration for XS708E
Hi Netgear support team, I was trying to register for my XS708E. However, when I keyed in my serial no. it says that the switch has already been registered. Why? Am I getting something that ha...
- May 02, 2016
HI Victorgo,
Just send us a PM so we can check. You may also want to follow mdgm's advice.
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
May 02, 2016NETGEAR Employee Retired
I have moved your post out of the ReadyNAS section to here. The XS708E is not a ReadyNAS, it is a switch.
It could well be that you bought an Amazon return if you bought it from there.
The warranty is for the original purchaser only when purchasing from an authorised reseller. If Amazon sold you a second hand unit as new you should take that up with them.
- VictorgoMay 02, 2016AspirantWould you be able to help me check who is this switch registered to? I will need some evident that this switch is not a new unit.
