NG18
Feb 24, 2020Aspirant
ReadNas Switch Setup
My ReadyNas when connected to a router is working fine. I want to replace the router with a switch. When I give static ip to the device and attach it to a switch, the computers don't see that NAS. Is...
- Feb 25, 2020
NG18,
When I give static ip to the device and attach it to a switch, the computers don't see that NAS. Is there how to for setting up ReadyNas with a Switch? TIA
Since you replaced the router with a switch, be reminded that the router is the DHCP server that provides local IP addresses to the computers. Unmanaged switches does not have the capability to provide local IP addresses because its purpose is to extend the local network so that you can connect more devices in the LAN.
On your current setup, now that you set a static IP address on the NAS, you will need to set static IP addresses to the computers that is within the IP address range of the IP address of NAS. For example, if the NAS IP address is 192.168.1.2/24, then you will need to set static IP addresses of 192.168.1.3/24 and 192.168.1.4/24 to PC1 and PC2 respectively so that the PCs will be able to access the NAS.
DaneA
NETGEAR Community Team
DaneA
Feb 25, 2020NETGEAR Employee Retired
NG18,
DaneA
- NG18Feb 27, 2020Aspirant
