csrazdan
Oct 24, 2013Aspirant
Suggestion for connecting NetGear switch to home network
Hi All, I recently purchases NetGear ProSafe 8-Port Gigabit Ethernet Switch GS108E. I would request your help/suggestions for connecting it to my home network. The other components which I have is...
- Retired_MemberOct 25, 2013Should had bought a new router in the first place. Your router is the problem. Check on their site for a solution.
Retired_Member
Oct 26, 201350 out of modem 25 out of router = bad router. Yes, it should work but it doesn't. You should seek guidance from cisco support. A lot of good general information but your problem has not been resolved.
Check the Cisco site for a FW update.
