csrazdan
Oct 24, 2013Aspirant
Suggestion for connecting NetGear switch to home network
Hi All, I recently purchases NetGear ProSafe 8-Port Gigabit Ethernet Switch GS108E. I would request your help/suggestions for connecting it to my home network. The other components which I have is...
- Retired_MemberOct 25, 2013Should had bought a new router in the first place. Your router is the problem. Check on their site for a solution.
jmizoguchi
Oct 26, 2013Virtuoso
Cat5 can handle upto 100Mbps so you are ok
M10 may connected to cable modem at half duplex
