csrazdan
Oct 24, 2013Aspirant
Suggestion for connecting NetGear switch to home network
Hi All, I recently purchases NetGear ProSafe 8-Port Gigabit Ethernet Switch GS108E. I would request your help/suggestions for connecting it to my home network. The other components which I have is...
- Retired_MemberOct 25, 2013Should had bought a new router in the first place. Your router is the problem. Check on their site for a solution.
Retired_Member
Oct 26, 2013In post 2 & 7 I suggested he seek support at Cisco. The last Cisco product I setup was a Cisco Catalyst 9000 16 years ago. I had no idea their home routers could be setup to negatively effect WAN to LAN throughput hence my response. I now know it's a sloooooow router.
Thanks
Op! you have a slooooow router not a bad router. LOL:eek:
Thanks
