csrazdan
Oct 24, 2013Aspirant
Suggestion for connecting NetGear switch to home network
Hi All, I recently purchases NetGear ProSafe 8-Port Gigabit Ethernet Switch GS108E. I would request your help/suggestions for connecting it to my home network. The other components which I have is...
- Retired_MemberOct 25, 2013Should had bought a new router in the first place. Your router is the problem. Check on their site for a solution.
csrazdan
Oct 27, 2013Aspirant
fordem wrote: Not necessarily.
50 out of modem 25 out of router = slow router - it doesn't mean the router is in any way defective - and it could be nothing more than how the user has chosen to configure the router/firewall.
I have default configuration.I mean have not changed anything accept the Admin password. Any help in configuration will be appreciated.
Talked to Cisco support and they conveniently said the router is out of support and suggest me to upgrade to EA6400. Looked for firmwere upgrade and upgrade to Ver.2.0.03 (build 4) 01/14/2011
