Peter2309
Oct 24, 2022Aspirant
Switch GS108v4
Hi, I have just purchased a Switch GS108v4 and have a basic question. Does it require a specific cable for the connection to the router? Does the cable to the router need to be plugged into a specifi...
- Oct 24, 2022
a decent quality cat 5e or better cable.
And you can use any port on the gs108. Its an unmanaged switch so any one will work.
