Peter2309's avatar
Peter2309
Switch GS108v4
Hi, I have just purchased a Switch GS108v4 and have a basic question. Does it require a specific cable for the connection to the router? Does the cable to the router need to be plugged into a specifi...
  • plemans's avatar
    Oct 24, 2022
    a decent quality cat 5e or better cable.
    And you can use any port on the gs108. Its an unmanaged switch so any one will work.
ProSupport for Business
