Homeuser66's avatar
Nov 25, 2015
What's the proper set up for my Netgear JGS524
Hi, I am new to the networking aspect of computers. I have an:   AT&T Gateway (5031nv) Asus Router (RT-AC68U) DirecTV GenieGo WD 4TB MY Cloud   My current set up is From AT&T gateway I have 1 ...
  • DaneA's avatar
    DaneA
    Nov 26, 2015
    Hi Homeuser66,
    Here is what BrianL is trying to tell you.  Kindly read the following below:
    A.  If ever the AT&T gateway is a combination of modem and router, then configure the AT&T Gateway as a modem-only device.  Then connect the Asus router directly to the AT&T Gateway.  This will make the Asus router as the main router.  Then connect the JGS524 switch directly to the Asus router to extend the local network.  Refer to the image below:
    B. If ever the AT&T gateway is a combination of modem and router then you could just remove the Asus router from the network setup.  This will make the AT&T gateway the main router.  Then connect the JGS524 switch directly to the AT&T gateway to extend your local network.  Refer to the image below:
    C. From scenario B, if ever the AT&T gateway is a combination of modem and router then you could just remove the Asus router from the network setup.  This will make the AT&T gateway the main router.  Then connect the JGS524 switch directly to the AT&T gateway to extend your local network.  For wireless access to the internet, you may configure the Asus router as an Access Point then connect it to the JGS524 switch.  Refer to the image below:
    Hope these helps.
    DaneA
    NETGEAR Community Team
ProSupport for Business
