MikhailCompo
Jun 23, 2025Tutor
XS508M Crashed. No Longer Have Any Confidence in This Device
My XS508M stopped working whilst I was away for work which is when I need my office network working reliably so caused me a lot of issues. Basically I use this as my main switch. My WAN router an...
Jul 09, 2025Guru - Experienced User
Any progress on this?
- MikhailCompoJul 09, 2025Tutor
It happened again and my whole LAN went down again.
It's unreliable and since it's a dumb switch with no configurable options there's nothing I can do to resolve this, its useless to me if it's not reliable.
I'm swapping it out and the replacement should arrive tomorrow.... this time NOT made by Netgear.
- FURRYe38Jul 09, 2025Guru - Experienced User
Possible you may have a faulty unit. You should make contact with NG support and ask about RMA options. Ask them about a cross shipping RMA. Well worth checking to this to see if unit is just faulty. My XS505M has been solid for past few years since getting it. All ports and the SFP are used for my needs.
- MikhailCompoJul 10, 2025Tutor
Thanks, sound advice. Any idea what the warranty terms/period is for these models?
