toya's avatar
toya
Tutor
May 22, 2021
100% CPU USED(MODEL: BR500)
hi
 I think vpn router has a issue.
 though I use about 20 devices (pc,sockets,cctv,nvr,smartphone),
 100% CPU Usage is too much.
 Before it was 20~30%(i guess).
 why is it happened?
thx
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    toya,
    What is the current firmware version of your BR500?  If ever its not yet the latest version, I suggest you to upgrade it.  The latest BR500 firmware is v5.10.0.5 and you can download it here.  Then observe if the same problem will occur.
    DaneA
    NETGEAR Community Team
ProSupport for Business
