bearbeatz
May 09, 2016Aspirant
3CX Phone Server, Secondary Addresses and PortForwarding
Hi, all- a small quandry. I am attempting to set up a 3CX phone server for a customer. The WAN's primary IP is already established at xx0.xx0.xx0.241 255.255.255.248. The client has a few more IPs at...
bearbeatz
May 10, 2016Aspirant
oops. #3 in Inbound should be titled "LAN Server IP Address"...
DaneA
May 11, 2016NETGEAR Employee Retired
Hi bearbeatz,
For us to check if the secondary WAN IP Address works, why not try to swap the primary WAN IP Address and secondary WAN IP Address. Make the .242 as the primary WAN IP Address then make the .241 as the secondary WAN IP Address on the SRX5308. As well as edit the Inbound and Outbound rules in the SRX5308 and the settings on the 3CX phone server to use the .241 as the WAN IP Address for the meantime.
If ever still won't work, kindly try to update the firmware of the SRX5308 to the latest version 4.3.3-6. Make sure to perform a factory reset on the SRX5308 after a successful firmware update then reconfigure the setting from scratch. Then, check if same problem occurs. Here is the link where to download the latest firmware v4.3.3-6.
DaneA
NETGEAR Community Team
