Rvreeswijk's avatar
Rvreeswijk
R7000 not portforwarding
Dear,
I want to host my own minecraft server just for my friends, i am new in the portforwarding scene and do not know much about this. So i followed a youtube tutorial of how to portforward for netgear routers.
First i went to CMD: Ipconfig were i found my IPv4 adress to use for portforwarding:
After this, i went to the router login and went to advanced tab, advanced settings and then port forward/activate port.
I created a new service page.
This was all i had to do in this tutorial that i have seen on youtube. After i did this, i went to the website: Whatismyipadress.com to see what the IP adres is for my friends to join to me. I runned the server and gave the IP and port to my friends. They were not able to join. I checked on a website if my port is open. It was closed. I have searched allot on google what i was able to do without succes.
I also added a rule in my virusscanner to add the port: 25565 and added java.exe as a rule. Without succes either. Someone know what i can do to solve this issue?
I added 2 photo's so you can see what i did. Thx!
thx for your patient!
  • antinode's avatar
    antinode
    Apr 05, 2020
    > [...] But if i want to set the modem to bridge mode, my netgear router
    > is not working. [...]
       There are many kinds of "not working".  "not working" is not a useful
    problem description.  It does not say what you did.  It does not say
    what happened when you did it.  As usual, showing actual actions
    (commands) with their actual results (error messages, LED indicators,
    ...) can be more helpful than vague descriptions or interpretations.
       I know nothing about how your EPC3940L was configured when it was a
    modem+router.  You might need to do things to the R7000 to make it work
    with your ISP when it's your main/only router.
       Did you try a settings reset on the R7000 after you changed the
    EPC3940L to modem-only mode?
    > [...] See picture 2. (Router IP:192.168.1.1) because the C (In
    > A.B.C.D) is a 1, i cannot reserve a adress for my port. [...]
       Regarding "cannot", see "not a useful problem description [...]",
    above.
       LAN addresses like "192.168.1.1" (for the R7000) and "192.168.1.2"
    (for your computer) seem normal to me.  You should still have a reserved
    address for your server system.
    > [...] Also with that C in my ipv4 adress i cannot port forward via my
    > modem because its a closed IPv4?
       Why not?  Regarding "cannot", again, see "not a useful problem
    description [...]", above.
    > [...] call my ISP tomorrow [...]
       They may be able to tell you if you need to specify any special
    settings on your (R7000) router when you're not using the router in the
    EPC3940L.
  • > R7000 [...]
       Firmware version?  Connected to what?
    > [...] So i followed a youtube tutorial [...]
       That's very odd. I once viewed a YouTube tutorial, and it had
    nothing to do with port forwarding on Netgear routers.  Is it possible,
    do you suppose, that there might be more than one tutorial on YouTube?
    > portforwarding:
       Not a very good beginning.  What happens to your port-forwarding rule
    next week, when your Windows system gets a different IP address?
    > [...] i am new in the portforwarding scene and do not know much about
    > this. [...]
       You've persuaded me.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Manage Port
    Forwarding and Port Triggering" and "Manage Port Forwarding to a Local
    Server".  Pay particular attention to:
          3. Assign the server computer a reserved IP address.
       I can't see what you put there, but let's pretend that you did
    everything right there.
    > [...] to see what the IP adres is [...]
       And that address was, ...?  (The top half, "a.b" out of "a.b.c.d",
    would satisfy my curiosity.)
       Does that address match the address of the router's WAN/Internet
    interface?  (ADVANCED > ADVANCED Home : Internet Port : Internet IP
    Address)  If not, then what's the routers WAN/Internet address?
       Can you access the server from a system on your LAN using the
    server's LAN IP address?  If you can't access the server locally, then
    there may be little chance of doing it from the outside world.
       If that works, then, still from a system on your LAN, try using the
    router's WAN/Internet IP address.  That should verify the
    port-forwarding rule(s) (and the "NAT loopback" feature of the router).
       One possibility is becoming a more frequent problem as more ISPs
    adopt carrier-grade NAT to conserve IPv4 addresses:
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
    But any other NAT router between your R7000 and your ISP would cause the
    same problem.
    • Rvreeswijk's avatar
      Rvreeswijk
      Good day, Thanks that you want to help me!
      I followed some of your steps
      My firmware version for now is V1.0.9.88_10.2.88. I have seen that there is a new firmware version and i want to update the router today.
      My PC is directly connected with ethernet cable to the router.
      I will send you the link of the video, it is 6 minutes. I followed it, in this video they also assign the server a reserved IP address.
       [...] I can't see what you put there [...]
      i will send a file with this message(picture 1) of how i filled the service tab in. (25565 is the port for minecraft)
       [...] And that address was [...]
      It is: 90.145.x.x. This is not the same Ip-adres that is written in the advanced home tab. This is 192.168.x.x
      [... ]Can you access the server from a system on your LAN using the
      server's LAN IP address? [...]
      Yes, i can acces the server from an other system on my lan using the server's LAN IP adress.
      Picture 1 is the picture how i filled in the advanced service tab.
      Pitcute 2 is a picture of my ipconfig.
      I hope you can still help me! Thx
      • antinode's avatar
        antinode
        Guru
           There are two IP addressses "in the advanced home tab".  Under
        "Router Information" is the "LAN Port" address.  (There's no need to
        hide that one.)  Under "Internet Port" is the WAN/"Internet IP Address",
        which is the important one.  If the _WAN/Internet_ IP Address is
        "192.168.x.y", then that would be the the problem.
           Ask your ISP?
           The only solutions I know are: 1) to ask your ISP for a real public
        address (for which they might charge more), or 2) to use a tunneling
        service like the one mentioned in another thread (near the end):
              https://community.netgear.com/t5/x/x/m-p/1748431
        Some ISPs do not permit servers for residential customers, but I'm
        confident that they'll tell you that if you ask.
