chiragk11
Nov 23, 2016Aspirant
Accessing specific VLAN after VPN based on user
Hello I have an SRX 5308. I have 3 VLANs defined. Default = 192.168.3.1 VLAN10 = 10.50.10.1 VLAN20 = 10.50.20.1 I need to define IPSec VPN, such that when user1 logs in, he gets the Defau...
DaneA
Nov 24, 2016NETGEAR Employee Retired
Hi chiragk11,
Kindly try to use the VPN Wizard on the SRX5308 to create both IKE and VPN policies for each VLAN.
Let us know the results.
DaneA
NETGEAR Community Team
- chirag11Nov 26, 2016Aspirant
I did try the VPN Wizard. But the configuration it created to start did not even let me connect.
Can you help provide some details on what values to set if I want to allow - any remote IP, using the User database, and allow access to specific vlan - say 10.50.10.0, AND Specifically disallow access to 10.50.20.0
- DaneADec 08, 2016NETGEAR Employee Retired
Hi chirag11,
I just want to follow-up. Were you able to access and read my response on the link I've provided? If yes, were you able to try it? If ever you were able to try it, kindly share the results.
DaneA
