DanGil
Mar 25, 2017Aspirant
Adding multiple VPN users to NETGEAR FVS318Gv2
I have read "https://community.netgear.com/t5/VPN-Firewalls/How-do-I-allow-multiple-users-to-VPN-in-at-once/m-p/985114" but I still cannot seem to configure the NetGear FVS318Gv2 to allow multiple us...
- Apr 03, 2017
On behalf of Dan_Z, thanks for the update. I'm glad to know that you were able to configure multiple users connecting at the same time. :) Also, it seemed that this forum thread is exactly the same concern as your post here.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
Dan_Z
Mar 29, 2017NETGEAR Expert
Hi DanGil,
Welcome to the community!
Here is the steps to config IPsec user on firewall.
1.On User->User page,add the user,select user type to IPSEC VPN User
2.Create Client-to-Gateway IPsec policy
3.Disable vpn policy
4.Go to VPN->IPSec VPN->IKE policies,edit XAUTH configuration to Edge Device,Auth type select User Database
5.Enable vpn policy
6.Config VPN client that can refer https://community.netgear.com/t5/VPN-Firewalls/How-do-I-allow-multiple-users-to-VPN-in-at-once/m-p/985114
Thanks,
Dan
- DanGilApr 02, 2017Aspirant
I followed the suggested steps but still no luck. I am going to reread the manual starting at Chapter 5 and see how I end up.
After rereading Chapter 5 I was able to implement the Extended Authentication (XAuth) and I now have multiple users connecting at the same time.
You can consider this issue solved.
Thank you.
Dan
- DaneAApr 03, 2017NETGEAR Employee Retired
Regards,DaneA
