DanGil's avatar
DanGil
Adding multiple VPN users to NETGEAR FVS318Gv2
I have read "https://community.netgear.com/t5/VPN-Firewalls/How-do-I-allow-multiple-users-to-VPN-in-at-once/m-p/985114" but I still cannot seem to configure the NetGear FVS318Gv2 to allow multiple us...
  • DaneA's avatar
    DaneA
    Apr 03, 2017
    DanGil,
    On behalf of Dan_Z, thanks for the update.  I'm glad to know that you were able to configure multiple users connecting at the same time. :)   Also, it seemed that this forum thread is exactly the same concern as your post here
    Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
