david78
Sep 17, 2014Aspirant
Administration service access from DMZ interface (Telnet; HTTP; HTTPS)
Hello; I am using the DMZ interface For my Web server. I would like to know if there any possibility to disable the telnet , http and https port which are used to manage the SRX5308 firewall. Su...
david78
Hello Fordem,
First of all thanks for your reply.
Do you have remote management enabled? ->NO
Have you restricted the management interface to a single network? -> See my comment below
Are you running different network ranges on the LAN & the DMZ? -> Yes , 192.168.1.1 and 192.168.10.1
Comment : The main problem is about having a compromised web server under the DMZ zone. If this one is compromised; the hacker could potentially try to access the Telnet port from the Firewall FROM the INSIDE DMZ network. This is what I would like to forbid. My question is : is there any way to disable/block such port 23 from the inside DMZ ?
