david78
Sep 17, 2014Aspirant
Administration service access from DMZ interface (Telnet; HTTP; HTTPS)
Hello; I am using the DMZ interface For my Web server. I would like to know if there any possibility to disable the telnet , http and https port which are used to manage the SRX5308 firewall. Su...
fordem
Sep 17, 2014Mentor
If remote management is disabled I would like to think that the router's LAN interface would/should not be accessible from the DMZ - although I must admit I have not tested this personally.
If this is not what you are seeing - I would consider it as perhaps a flaw or oversight in the firmware and suggest you open a ticket at my.netgear.com and have it escalated so that it can be corrected.
I would also like to think that you can create a rule in the DMZ-LAN rules that would block any service/port you chose, but again I have not tested this.
