Aristomastrosi's avatar
Aug 11, 2021
Alternative for BR200/BR500 for 10GBit/s
Dear community,
I have a couple of BR200/BR500 routers coupled with many other insight products from the business series. Recently, my provider upgraded all fibre optic speeds from 1Gbps to 10Gbps. Since the BR200/BR500's cap at 924 Mbps WAN/LAN throughput, I was wondering if there is an alternative from netgear with comparable features. I'm receiving via DHCP request a public IP via ethernet. I guess I could use a managed switch (routing capabilities), but I would loose all the other security features like SPI as far as I'm aware of. Any ideas?
Thanks a lot and best regards,
Aristo
  • Aristomastrosi,
    There is no alternative as of now.  I suggest you post your concern as a product/feature request in the Ideas Exchange for Business board here.  In this way, the development team can see what product/feature does users wanted.  Be reminded that the more kudos given by community members to your product/feature request will help as the development team will be reviewing the post that has the most kudos and might get considered.
    DaneA
    NETGEAR Community Team
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Aristomastrosi,
    DaneA
ProSupport for Business
