BrendanM
Sep 26, 2024NETGEAR Expert
BR200 & BR500 Insight connectivity issue
There is currently a problem which is causing BR200 and BR500 devices to disconnect from Insight. NETGEAR are urgently working on a firmware fix to address this problem. When the fix is available, due to the nature of the problem, the firmware will need to be applied locally via the device admin page.
- BrendanMNETGEAR Expert
The firmware to address the problem is available at the links below.
For BR500:
https://kb.netgear.com/000066359/BR500-Firmware-Version-5-10-0-6
For BR200:
https://kb.netgear.com/000066360/BR200-Firmware-Version-5-10-0-6
Uploaded/Updated and works great.
Thanks Brendan (and Netgear team!)
-Brent
- JEDIVApprentice
When I just tried to upload the new image, I got the message "400 Bad Request - This server does not support the operation requested by your client"
I tried two different browsers to login to the local UI browser page for the BR500.
Any thoughts?
I was hoping that this update would solve the cloud connectivity problem, but I can't seem to get the update loaded.
- c3po2Apprentice
Which browser were you using? Could you please try different browser or incognito mode to see if problem persists?
