Kelvdon's avatar
Kelvdon
Guide
Apr 27, 2026
Since Insight update, the app does not show connected clients.
I have the same problem with SXR80. Insight 10.0.0 update (SXx80 firmware 4.3.4.300). Since Insight update, the app does not show connected clients. When I log on to the router (192.168.x.x) it shows all the connected clients, so definitely an Insight issue. In the insight app under location>wifi, it shows 23 , under health>wireless it shows 7, but when you go to click through to see the clients, nothing shows. When you click through normally to device>connected clients, nothing shows. It is becoming annoying. Any help appreciated
  • The app update 10.0.3 has fixed the clients not showing. However it has introduced a new problem of not being able to clear disconnected clients.
  • FURRYe38's avatar
    What phone platfrom are you using? Apple or Android?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
    Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
      • FURRYe38's avatar
        Something to make contact with NG about. Check the Technical Support link in the app.
  • The issue is the same on the web version of the Insight management portal and the iOS (Apple) version 10.0.0. Have restarted network in sequence prior to posting.
    • FURRYe38's avatar
      How about a factory reset and setup from scratch using the SXRs web page setup routine using a ethernet connected PC and web browser?
      • Kelvdon's avatar
        Kelvdon
        Guide
        That seems a bit drastic considering it’s an update issue with the insight management portal. The management portal is not reflecting the router management page. I think I’ll wait until the first insight update. Everything was fine until the update last week.
  • BrettD's avatar
    BrettD
    NETGEAR Employee
    Please raise a support ticket for this, feel free to send me the case number via direct message so that I can follow up internally. Just confirming, you have the new updated Insight UI?
    • Partha21g's avatar
      Partha21g
      Tutor
      Hi Bret, many thanks. My SRX80 attached to the new insight version app version 10.0.0 and cloud version 10.0.3.4 on iOS latest.
      SXS80 firmware. 4.3.3.300
      unfortunately I am out of support for the device and three satellites. Not sure how to raise a support ticket.
      I do have another SRX80 - on support but not connected to this network. It’s my back up kit in case for a hot fix failure
      • FURRYe38's avatar
        Just checking my SXK30 system, after getting it all FW v4.3.4.300  manually updated and did a full on factory reset and set up from scratch using a PC and web browser first, Insight app connected and giving that a few minutes, the app is showing devices connected with in the app for me. Though I only have 3 devices connected currently. Shows my iPhone 17, Galaxy Tab 7 FE and a ethernet connected PC.
        I'll add some more devices over the weekend and check again.
    • Kelvdon's avatar
      Kelvdon
      Guide
      Hi Brett
      Unfortunately I have not got support left. I just ran through 5 years (been an excellent system without any previous issues) and did not renew. I have full target compliance and issue shows on web and app versions of insight.
      • FURRYe38's avatar
        Can you confirm FW version that is on your SXK80 system please?
  • BrettD's avatar
    BrettD
    NETGEAR Employee
    This issue in the mobile app has been fixed and will be implemented in the next release, yet to confirm exact release date.
  • Glad I found this thread and waited before performing a factory reset. Can confirm the latest app v10.0.3 released on 6/10 fixed this issue. Now all my connected devices are showing up in the app.
  • FURRYe38's avatar
    Any progress on this? Seems like there is a new app update that should resolve this.
  • Same here ---- Insight app  version 10.0.3 now correctly displaying connected clients.
ProSupport for Business
