Kelvdon
Apr 27, 2026Guide
Since Insight update, the app does not show connected clients.
I have the same problem with SXR80. Insight 10.0.0 update (SXx80 firmware 4.3.4.300). Since Insight update, the app does not show connected clients. When I log on to the router (192.168.x.x) it shows...
- Jun 25, 2026
The app update 10.0.3 has fixed the clients not showing. However it has introduced a new problem of not being able to clear disconnected clients.
Partha21g
May 08, 2026Tutor
Done all the steps. Not fixed.
May 08, 2026Guru - Experienced User
Something to make contact with NG about. Check the Technical Support link in the app.
- schumakuMay 08, 2026Guru - Experienced User
Unless customers have a almost new device entitled for initial installation support - no joy.
Head to my.netgear.com from a web browser, login, head to support, and use Get Support on two for three different pages. There don't select a product - instead select I have a service, there select Insight and continue your luck. As of writing, Chat has a waiting time of 78 minutes, and the Call Support from is looping, broken for months, for almost half a year now. Don't know what Netgear IT does on their main job - plumbing or painting? Extreme disappointed about what should be Netgear support.
- jimchaoMay 08, 2026Aspirant
My SXR80 bought on 2023, app shows online support expired
