Kelvdon
Apr 27, 2026Guide
Since Insight update, the app does not show connected clients.
I have the same problem with SXR80. Insight 10.0.0 update (SXx80 firmware 4.3.4.300). Since Insight update, the app does not show connected clients. When I log on to the router (192.168.x.x) it shows...
- Jun 25, 2026
The app update 10.0.3 has fixed the clients not showing. However it has introduced a new problem of not being able to clear disconnected clients.
BrettD
May 08, 2026NETGEAR Employee
Please raise a support ticket for this, feel free to send me the case number via direct message so that I can follow up internally. Just confirming, you have the new updated Insight UI?
Kelvdon
May 09, 2026Guide
Hi Brett
Unfortunately I have not got support left. I just ran through 5 years (been an excellent system without any previous issues) and did not renew. I have full target compliance and issue shows on web and app versions of insight.
- FURRYe38May 09, 2026Guru - Experienced User
Can you confirm FW version that is on your SXK80 system please?
Kelvdon wrote:
I have the same problem with SXR80. Insight 10.0.0 update (SXx80 firmware 4.3.4.300). Since Insight update, the app does not show connected clients. When I log on to the router (192.168.x.x) it shows all the connected clients, so definitely an Insight issue. In the insight app under location>wifi, it shows 23 , under health>wireless it shows 7, but when you go to click through to see the clients, nothing shows. When you click through normally to device>connected clients, nothing shows. It is becoming annoying. Any help appreciated
- KelvdonMay 10, 2026Guide
Sorry, it 4.3.3.300 as shown attached
- FURRYe38May 10, 2026Guru - Experienced User
Ok, thank you for checking that.
I see that the version is one behind where the SXK30 is. I'm wondering if that maybe the issue with the 80 series vs 30 series as my 30 series is showing connected devices, both on web ui and Insight app, though my trial for the Insight app is now over so thats not accessible anymore for my system, unless I purchase a credit for it.
Hoping that NG can release one more fix for the 80 series system.
