Kelvdon
Apr 27, 2026Guide
Since Insight update, the app does not show connected clients.
I have the same problem with SXR80. Insight 10.0.0 update (SXx80 firmware 4.3.4.300). Since Insight update, the app does not show connected clients. When I log on to the router (192.168.x.x) it shows...
- Jun 25, 2026
The app update 10.0.3 has fixed the clients not showing. However it has introduced a new problem of not being able to clear disconnected clients.
Apr 27, 2026Guru - Experienced User
What phone platfrom are you using? Apple or Android?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Partha21g
May 08, 2026Tutor
Done all the steps. Not fixed.
- FURRYe38May 08, 2026Guru - Experienced User
Something to make contact with NG about. Check the Technical Support link in the app.
- schumakuMay 08, 2026Guru - Experienced User
Unless customers have a almost new device entitled for initial installation support - no joy.
Head to my.netgear.com from a web browser, login, head to support, and use Get Support on two for three different pages. There don't select a product - instead select I have a service, there select Insight and continue your luck. As of writing, Chat has a waiting time of 78 minutes, and the Call Support from is looping, broken for months, for almost half a year now. Don't know what Netgear IT does on their main job - plumbing or painting? Extreme disappointed about what should be Netgear support.
- jimchaoMay 08, 2026Aspirant
My SXR80 bought on 2023, app shows online support expired
