BrendanM
Sep 26, 2024NETGEAR Expert
BR200 & BR500 Insight connectivity issue
There is currently a problem which is causing BR200 and BR500 devices to disconnect from Insight. NETGEAR are urgently working on a firmware fix to address this problem. When the fix is available, du...
JEDIV
Sep 27, 2024Apprentice
When I just tried to upload the new image, I got the message "400 Bad Request - This server does not support the operation requested by your client"
I tried two different browsers to login to the local UI browser page for the BR500.
Any thoughts?
I was hoping that this update would solve the cloud connectivity problem, but I can't seem to get the update loaded.
c3po2
Which browser were you using? Could you please try different browser or incognito mode to see if problem persists?
