KENDQ
Mar 06, 2016Aspirant
android vpn
I was useing my samsung galaxy phone's VPN software to tunnel in to my business camers (useing my FVS318N router) till my son did a hard reboot on my phone. I know it was useing the advanced vpn cli...
DaneA
Mar 07, 2016NETGEAR Employee Retired
Hi KENDQ,
I do not own a Samsung Galaxy phone and I have not yet tried to have a VPN setup on any android phone. However, let me share this link as reference guide and this might help.
DaneA
NETGEAR Community Team
- KENDQMar 07, 2016Aspirant
Thanks for the reply
in that link under user tab it shows pptp for user type, having a newer version of the firmware my choices are
SSL VPN user
Administrater
Guest
IPSEC vpn user
L2TP user
(I Think My old config was using IPSEC)
Ive been playing with This for hours next time I will write it down
Follow up
I Notice The only vpn user my router has listed under user is also IPSEC (as I say this worked till 2 days ago and Router has not been changed)
On the phone my choices are
Pre-shared key (IKEV1)
Pre shared key (IKEV2)
Certificate (IKEV1)
Certificate (IKEV2)
EAP AND CERTIFICATE (IKEV2)
L2TP PRESHARED KEY (IKEV1)
L2TP Certificate (IKEV1)
Secure ID (IKEv1)
also under advanced Choices are
Extended Authentication
Aggresive Mode
Perfect Forward secrecy (PFS)
Dissable split tunneling
Algorrithm Suite (Default is "ANY")
ike Groups
(my wifes Iphone stiil works useing the Ipsec and my shrew soft is also still working)
