race
Oct 05, 2015Aspirant
Attempt to release incorrect UDP nat port from SELF
Two months ago, my Netgear router logs began to include intermittent entries that said, "Attempt to release incorrect UDP nat port from SELF." More and more of these entries began to show up. Cur...
SamirD
Oct 19, 2015Prodigy
The proof to comcast is as simple as this: find out your puclic ip from a website, check the netgear wan ip. When they do not match, send them screenshots.
The netgear should have the public ip address at all times if everthing is working correctly.
- raceOct 27, 2015Aspirant
I showed the screen shots to the Comcast tech, and they had several other explanations that I have disqualified but I must investigate with documentation so that I can prove this. These explanations include the modem firewall settings, the modem bridge settings, etc.
I'll report back in a few days.
