SquareJ
Aug 27, 2022Aspirant
BR200 - How do i enable syslog?
Is it possible to enable syslog on a BR200 device? If so then how.
Thanks
1 Reply
The BR200 is a "Managed Business Router" rather than one of the "bog standard" consumer devices covered here.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:Hardware VPN Firewalls and Business Routers - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
