TKR815
Dec 29, 2020Aspirant
BR200 Cloud LED off and on
Using BR200 vpn router for home business, have setup using web gui and device shows up on insight mobile app, created three vlans. But I cannot seem to find information on the "Cloud" led light on fr...
schumaku
Dec 29, 2020Guru - Experienced User
It should be on, virtually 24*7, as it indicates the connection to the Insight cloud is established.
TKR815
It does not, it is intermittent it may come on for few minutes then goes back off. It is connected to a netgear cable modem which has dhcp but not sure what could be interferring with cloud connection. DNS on router is set to cloudfare. any suggestions other than reset it?
