TonioRoffo
Jul 16, 2021Follower
BR200 disable NAT
Hello, I'm looking to put the BR200 in a network where the internet breakout is further on the WAN chain. So I don't want NAT between LAN & WAN on the device - just plain routing. Is this po...
ZbigT
Jul 16, 2021Guide
Hello,
while I don't run BR200 in this configuration, I'm pretty sure you should be able to achieve that by just not using the WAN port. You have the flexibility to define separate LANs, assign them to VLANs and them, in turn, to different switch ports (either 802.1Q-tagged or untagged). Then you can use "Traffic Rules" to allow or disallow inter-VLAN traffic based on several criteria and are free to ignore the existence of the WAN port the whole time.
Best regards,
Zbig
