GrayHairCoder
Apr 14, 2022Tutor
BR200 replacment
Have a BR200 that has hardware issues Netgear has agreed to replace it but is seems they don't have a suggestion as to what would have the same configurable capabilities is as the BR200. I read many ...
Geoff-NZ
May 01, 2022Apprentice
It appears both the BR200 and BR500 are EOL and it doesn't look like Netgear have any business VPN routers now. Therefore, it depends on your requirements, the performance, throughput, and the amount of security you need as to what would be a suitable replacement. For a netgear router you will probably have to look through the "home" WiFi routers or WiFi Cable routers depending on your Internet connection. If you want a dedicated VPN router, there are other options in the market, just depends on what you need.
