magitech
Aug 11, 2021Aspirant
BR200 reservation not working
Hi,
I am trying to setup the "Address Reservation" on my BR200 but it is not working.
The reservation works well with my windows clients but doesn't work with my ip cams. Router assigns to each IP cam an IP different from the one reserved.
Do you have any suggestion to solve this issue?
Fabio
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Kindly answer the questions below:
1. Was this working fine before?
2. What is the current firmware of your BR200? If ever the firmware is not yet the latest version, I suggest you to update it. You can download the latest BR200 firmware v5.10.0.5 here. Then, check if the same problem will occur.
3. What is the exact brand/model of your IP cameras?Regards,
DaneA
NETGEAR Community Team
- magitechAspirant
Hi DaneA,
1. I have just bought the router and this is the first time I used it. Other stuff seems to work correctly and also reservation works with windows clients;
2) The firmware version is already V5.10.0.5 update via Insight
3) I have tried these type of IP cams: D-Link DCS-2210 and Reolink RLC-420
Thanks,
Fabio
- magitechAspirant
An update, the address reservation actually works only for one windows client.
On other two clients, the reservation doesn't work.
- kohdeeNETGEAR Expert
- magitechAspirant
