jmcdpugall
Jan 29, 2020Tutor
BR500 and Panasoniv Voip
Hi, I wonder if anyone out there has seen similiar issues. I have 2 VPN 500 routers with an Insight VPN tunnel between them. One side has the IP address of 10.0.0.254 and the other is 10.0....
DaneA
Jan 29, 2020NETGEAR Employee Retired
Welcome to the community! :)
The registration process is automatic. Is there a reason why traffic passing across the vpn appears as if has come from the router, rather than the original device?
It appears that both sites: 10.0.0.254 and 10.0.8.254, appears (or somewhat detects) to be a one whole subnet. For me, site A and site B should have a different LAN IP addresses. For example, Site A has a LAN IP address of 192.168.1.0 while Site B has a LAN IP address of 172.16.30.0.
DaneA
NETGEAR Community Team
jmcdpugall
Jan 30, 2020Tutor
Hi Dane,
Thanks for the response.
The Networks subnets have a subnet mask of 255.255.255.0 should be identifed as seperate subnets. All other traffic passes between sites with out issue. I can access resources on both sides of the VPN tunnel without issue. The only problem I have is that the PABX is seeing the source IP of the phone as the local router IP.
- c3poFeb 05, 2020NETGEAR Expert
Could you please try to disable SIP ALG to see if it makes difference? Thanks.
Web GUI -> ADVANCED -> Firewall -> Basic Setup -> Check "Disable SIP ALG" on bottom -> Apply
- jmcdpugallMar 03, 2020Tutor
Hi, sorry for the delay. SIP ALG is disabled on both routers.
All other services seem fine, just the Panasonic phones playing up.
Help!!!
- c3poMar 03, 2020NETGEAR Expert
In that case, would you please try to enable SIP ALG on one or both sites, you have a few combination to try though: Remote 10.0.8.0 BR500; PBX 10.0.0.0 BR500; or Both.
https://docs.skyswitch.com/en/articles/578-what-is-sip-alg-and-should-it-be-on-or-off
Or if possible, manually register 10.0.8.98 with PBX 10.0.0.45 with local IPs.
VPN
SIP ALG
NAT
PBX
All can affect how SIP is being processed, sorry that you may need to try and error to see which setting works since we don't have same PBX/handset to try in our lab.
