skerps
Feb 25, 2022Aspirant
BR500: "CPU occupancy rate is high. Check the router."
I have had my BR500 for about a year and over the past 6 months the CPU utilization is anywhere from 60-80%. I have rebooted and made sure the firmware is on the latest version. (Firmware Version: V5...
JohnC_V
Mar 04, 2022NETGEAR Employee Retired
Hi skerps,
Welcome to our community! :)
It seems that you were having issues with your BR500. How many devices are connected to your network? How many VLANs? Please try doing a backup of the configuration and resetting it to factory default. Please check if it will show the same CPU utilization after factory default, if it worked, then try to re-upload the backup file and see it from there.
John
NETGEAR Community Team
- skerpsMar 04, 2022Aspirant
My appologies I have a BR200 not a BR500. I have about 15-20 devices connected on one subnet and 1 Vlan for Wifi. I have tried to perform the factory reset and the CPU usage is low then when I start connecting devices it goes up again after a day or so. I've tried restoring my confirguration from a backup at first and also without restoring the config (configuring manually) but the issue remains. Thanks in advance for any assistance with this.
