slamers74
Sep 27, 2020Aspirant
BR500 DHCP via WAC510 - Not working on VLAN1
A week ago I replaced my BR500 router (due to an ongoing issue with regular disconnect/psuedo reboots). I was able to capture the configuration and get it set back up the way the old one was. Had a b...
DaneA
Oct 04, 2020NETGEAR Employee Retired
Found out from the NETGEAR Support Team that a support ticket has been opened regarding your concern. You can login to your MYNETGEAR account and send a follow-up message through the support ticket. Also, you may want to post here the progress of it.
DaneA
NETGEAR Community Team
